First of all my apologies if it sounds like I'm "teaching my granny to suck eggs" but from some of the posts I have read it's obvious that not all contributors are qualified. So if you are just an enthusiastic DIYer or lack the basics then read on:
A few years ago (must be 25 years at least) when I worked for my local Electricity Generating Board (YEB) I was installing a shower circuit for a customer.
To cut to the chase ('scuse pun) I had installed the cable 6mm T&E. I think 6kw was the average shower back then. I was in the process of terminating the cable into the fuse board (Power was turned OFF) but nipped out to my van for a new fuse carrier. When I returned 2 or 3 minutes later I picked up where I had left off.
"WHACK". One hell of a belt up my right arm and across my chest and one screwdriver with the end melted. Anyone who tells you mains voltage doesn't hurt is talking crap. I was lucky. No permanent harm done.
What had gone wrong? I had been working on a dead circuit because I had isolated the main supply. However, we didn't lock off the circuits back then unless the supervisor came out on a visit. While I had nipped out to the van, the customer had decided he wanted a cup of tea so he switched the power back on. I gave him a *******in' but "sorry" is not much use after the event .
That's one lesson I'll never forget. Check it, lock it off and check it again. If you leave the room then check it on your return. Be safe mate, not sorry.
Oh, and make sure you have a decent voltage detector that also has the ability to carry out a single pole phase test.
Mike
Mike
