I have just installed a Mira Go electric shower in my house
I wired the shower unit and plumed it in. I turned the power and water back on to test the shower. I pulled the cord for power to the shower but the led did not come on, I switched the trip for the shower on and off on the fuse board and the led started to work.
I hit the on switch on the shower but for some reason nothing happened but the led on the pull cord switch went out and when I turned the shower off again the led came back on. At no point during any of these steps did the shower spring into life, no water, no lights no nothing.
I removed the cover on the shower and checked the wiring but all was as it should be. I can only assume that there is a loose connection somewhere on the circuit but I don't have a voltage test meter to check.
I don't suppose someone can tell me what is wrong with the blooming thing. Or if I have overlooked something.
Any help or advise would be greatly appreciated.
