Good morning.
I'm new here and this is my first post.
Yesterday I had a new electric oven installed. I understand they are a universal size and it fitted into the recess quite nicely. The installers tested all the electrics and hard wired the electric oven in, putting a new fuse socket into the wall as well.
The only slight issue is that the oven was a tiny bit narrower than the recess, so when they went to screw the oven in (at the front by the oven door) the screws have caught the edge of the inside of the MDF recess panels, and nor embedded properly, so if I try to pull the oven out it comes out quite easily.
Behind the oven are gas pipes feeding the pre-existing gas hob, which was not touched, so I dont really want any movement if anyone is a bit heavy handed with opening or closing the oven door, as the back of the oven is no doubt very close to the pipe.
The electric oven is a NEFF, which has a slanted section at the back top, which is specificially good to fit in these circumstances under gas hobs.
It was Curry's KNOWHOW team that installed it - should I contact them to come and rectify it or just try and put some bigger screws and angle them in - so hopefully they will embed into a more central bit of the thickness of the side of the MDF recess panel ?
The only other issue is the front of the oven is proud by about 5mm - I'm not bothered about this and it doesn't notice, but obviously from the side with the door open you can see about 5mm of the screw.
Thanks in advance for any opinion
Steve
Steve
