electric chair
it crosses the doorway
SO????
How did you propose to cross the extra low voltage cable across the door 'ole? Why do you think you cant use the same method with mains voltage cable?
thanks again for reply
i intended cllpping cable around doorway and the extensions that i thought was suggested were too thick,,,,, can u explain what cable u mean
i didnt suggest any. are there no sockets on the other side? can you move the chair?
just extend the flex if you must, but use a joint with cord grips, not a round 30 amp junction box.
yes sorry steve thought it was your last post
would a 13amp flex connecter be suffice
