Electric drill required for 4" thick concrete?
24 Dec 2013
hi - i need to drill 10 holes 7/8" dia and 4" deep in a concrete floor for the purpose of securing the lifting posts of a new mid-rise car lift.
problem is i only have a 1/2" 570W b&d hammer drill & will obviously be useless.
can anyone therefore please advise on this as i would buy suitable if not too expensive.
cheers
Blimey - Just hire a SDS drill for the day. They may even have the bits for you!
My old B&D will do 22mm which is a bit smaller but definitely pushing it!
So I invested in buying an SDS, but then I do get plenty of use out of it to make buying worthwhile
http://www.screwfix.com/p/titan-ttb278sds-5kg-sds-drill-240v/97533 Good value if you fancy buying - it's a shame your bit size is not included
You could probably get there with your own drill if you went 5mm 8mm 12mm 16mm and so on until you get to your size, unless of coarse you are angling for a new drill for christmas :wink:
if the wife reads this i'll be getting all those bits for christmas instead - cheers!!
cheers for that - ordered one + 1 roll of insulating tape to get it over the £50 for free shipping - to be honest i'd never heard of a sds drill but i've away from the tools other than servicng the family cars for over 20 yrs.
Good luch with that - I bet you find other jobs for once its in your hands! If the setting out of the hole tolerances are tight I would still use the smaller drill to create a pilot hole dead on position. It also makes it easier for the big bits to follow. I also always mark my centres with a big X so I can check alignment with the remaining parts of the lines as the hole is being drilled
