Electric Heated Towel Rails - Bathroom
1 Dec 2008
Yorkshire
Hello All,
This is my first post, I am a DIY novice and I really need some advice!
I have an Electric Heated Towel rail in my en-suite bathroom, and something is amiss as the top rail of it is stone cold. The rest of it is ok but it isn't heating the room very well. It is purely electrical as we don't have central heating as I live in a flat.
I notices that there are two screws/bolts at the top on each side (the towel rail is H shaped) which i wondered if this needed to be 'bled' in the way that a normal water filled radiator would - does anyone know?
Any help would be greatly appreciated - even if its just to let me know its broken and i need a new one!
Thanks,
Andi.
Does it connect to anything ?
If not and you bled it - how does the "water?" come out - its not under pressure from C/H system ?
I'm confused now too ??!!
Stoyer
It's not connected to anything, I wasn't thinking of letting liquid out, just air.
Thanks,
Andi.
Hello,
To let air out, the space left will need to be filled with another substance ?
If it is not connected to anything - air will not come out ?
Is the space supposed to be there to allow for heat expansion of the liquid that's heating up inside ?
I am no expert here but thinking logically ?
Anyone else have any ideas ?
Stoyer
Hi
Had another thought - maybe the rail comes with no water and is filled after installation ?
Maybe - while its cold you could slacken carefully the "bleed screw" ?
Maybe its requires a "top up" of water - if indeed its water that's inside ?
Hope any of this is helpful,
Stoyer
From what I've seen online they normally have an element inside and water at the bottom but I'm not sure for certain. Thanks for your suggestions though!
A.
Be Very very careful before putting water into an electrically heated towel rail. Sunds like a recipe for absolute disaster if its not supposed to have any!!
Why not, switch it off - remove one of the top plugs and drip a wick in.
Should be able to tell from that whats in it ?
