Hi all
Can anyone help me with any info on minimum clearances for brickwork between any openings and an external electric meter box.
Extension underway and i just want to check if there are any regs covering the fitting of the box.
The location of our electric meter box is planned to be between an abutment wall and a new external window.
At the moment i have allowed some 600mm minimum between window and box and box to abutment wall ( ie 600mm either side)
Box height will be minimum 450mm ( in reality it will be higher) from DPC which is correct to paperwork supplied with the box.
Sorry if this is in the wrong section.
Thanks to all in advance
Tufty
Tufty
