Electric oven + gas hob + washing machine on spur
31 Mar 2008
Surrey
We want to install an electric oven and gas hob in replace of the gas oven that was already there. There is only 1 socket under the work top (on the ring main). How am I going to run a washing machine + electric oven + gas hob ignition off this one socket? Shall I use a extension cable :wink:
I was thinking about taking a spur out the side of the socket up to the top to a on/off switch then back down to a double unswitched socket where i can plug in the hob ignition and the oven. Then I will still have the one socket (from which I am taking the spur cable) free for the washing machine.
Any other ideas comments about this?
Cheers,
Stu
As its a gas hob and electric cooker it sounds like the cooker will not be just a fan circulating the heat. You need to find out what load the cooker is at it wll probably need a seperate circuit of its own. You would also be better extending the ring for the washing machine.
All of this work is notifiable under Part P
Its max load is 2075 Watts. It says in the manual that it needs a cooker control circuit with a 20amp fuse.
Extending the ring is going to be a pain for the washing machine, especially since it has been working fine for over a year off the normal socket, the real trouble is to install the oven (an electrolux eob51001x).
Cheers,
Stu
