    Dismiss Notice
electric relay (coil) replacement 220/30 V
Discussion in 'Plumbing and Central Heating' started by gibson Ri59+!B+?, 18 Jan 2021.
  1. gibson Ri59+!B+?
    gibson Ri59+!B+?
    18 Jan 2021
    2
    Thanks Received:
    Country:
    looking for replacement coil for relay in Danfoss 57 H1 control box dimentions 37mm long 15mm dia.
  2. Sponsored Links
  3. oilhead
    oilhead
    29 Nov 2009
    2,020
    Thanks Received:
    476
    Shropshire
    Country:
    I think you'll be looking for a long time. These units have been obsolete for 30 years. Replacing with a current Satronic box and base is simple and reasonably, though you'll need to replace the photocell as well.
  4. bernardgreen
    bernardgreen
    3 Nov 2006
    24,305
    Thanks Received:
    2,375
    Bedfordshire
    Country:
    Refurbished units seem to be available from HERE
  5. gibson Ri59+!B+?
    gibson Ri59+!B+?
    18 Jan 2021
    2
    Thanks Received:
    Country:
    Thanks Bernard,
    Yes noticed that site early on , sent them e-mail and tried phoning but outfit seems to have closed down . I've been in touch with Heating-Parts.co..uk in Bridgewater who have two Danfoss items which they say will function as replacements for the 57 H1 , should receive them tomorrow . The boiler was little used in the 45 years I've had it , the coil failed due to a 10kohm resistor going down to 9.12k . The boiler a Harcal 430 is built like a Boeing 747 and all the advice I've read was to try to hang on to it as today's replacements don't match up to it .Anyone with an old control unit of any manufature that contains a relay would suffice to provide the coil that I need to get this control unit functioning again .
  6. oilhead
    oilhead
    29 Nov 2009
    2,020
    Thanks Received:
    476
    Shropshire
    Country:
    Your control box is the least of your concerns with a Harcol 430 if anything ever happens to the fan and motor, or the drive dog to the oil pump.
    Whilst the 'hang on to it' theory is valid for later standard efficiency boilers, this one will be quite inefficient.
  7. Terrywookfit
    Terrywookfit
    19 Jul 2007
    5,564
    Thanks Received:
    1,040
    Country:
    I used to convert to a Satronic TF 801 B and FZ cell which was same diameter as original.
    To OP I still have A static disc and Fan spacers if you need them !
  8. Sponsored Links
Loading...
Share This Page
