Electric Shower Problem
15 Apr 2011
Yorkshire
Yesterday the shower went off whilst in use. It tripped the RCD. After checking all the connections in the pull switch and shower I found a loose connection in the Shower Unit itself. When tested the problem is now that the shower comes on as soon as you switch on at the pull switch. It shouldn't as the shower unit has an on/off switch with a phased shutdown. What is causing this?
Did you have a choice of terminals to reconnect it? I'm no expert on shower internals but it sounds as though you've connected to a permanent live instead of a switched live ...
PJ
Make and model of shower?
One possibility is that when replacing the shower cover, you have jammed the switch in the on position, or crushed/damaged the wires connected to the switch.
Or the shower is broken.
Its a New Team 8.5kw. I have rechecked all the connections and all are in the right place and secure. Things have got worse now as when you switch it on at the pull switch it trips the RCD
How is that worse? It tripped the RCD initially.
Sounds like the shower is kaput.
Power down, disconnect the feed to it, make the ends safe, then reapply power.
When you switch on the supply, does it trip the RCD?
sounds like you have a faulty pcb which is sending constant power to the solenoid coil so getting water flow soon as pullcord is on.
what is it the mk 2 or 3 ?
