Yesterday the shower went off whilst in use. It tripped the RCD. After checking all the connections in the pull switch and shower I found a loose connection in the Shower Unit itself. When tested the problem is now that the shower comes on as soon as you switch on at the pull switch. It shouldn't as the shower unit has an on/off switch with a phased shutdown. What is causing this?
