- Joined
- 5 Feb 2012
- Messages
- 2
- Reaction score
- 0
- Country
DO I NEED TO electrica EARTH STEEL LINTEL FRAME for my new sun lounge
also do i need to cover twin and esrth cable befor been plasterdDO I NEED TO electrica EARTH STEEL LINTEL FRAME for my new sun lounge
No see hereDO I NEED TO electrica EARTH STEEL LINTEL FRAME for my new sun lounge
No, there is nothing in the regulations that require it.[also do i need to cover twin and esrth cable befor been plasterd
Depends if the are in prescribed safe zones or not?also do i need to cover twin and esrth cable befor been plasterdDO I NEED TO electrica EARTH STEEL LINTEL FRAME for my new sun lounge
That's not capping, though, is it?Depends if the are in prescribed safe zones or not?also do i need to cover twin and esrth cable befor been plasterdDO I NEED TO electrica EARTH STEEL LINTEL FRAME for my new sun lounge
If you have a cable running diagonally between accessories, they must be mechanically protected or buried at a depth of at least 50mm from the wall surface (that's both sides of wall)
I never mentioned capping, but the OP needs to be aware of this, others mentioned capping not I!That's not capping, though, is it?
Valid point.in the vast majority of properties (brick/block) this is not possible because of the Building Regulations.
