Electrical problem had knock on effect for central heating
Discussion in 'Plumbing and Central Heating' started by BrianCopper1, 26 Mar 2011.
  1. BrianCopper1
    BrianCopper1
    26 Mar 2011
    8
    Thanks Received:
    Lancashire
    Country:
    Hi, please help I had an electrical problem at home that needed correcting so i switched off the power and sorted job. However, since then my central heating and hot water is not working. I have checked pilot light and that is working I have power to timer and presumably room thermostat (but not checked that) I have changed fuse in the spur and now I am stuck. Any ideas? My family are moaning at me and I need to get this fixed without the help of British Gas if possible skint! Cheers!
  2. Sponsored Links
  3. seco services
    seco services
    3 Dec 2007
    15,701
    Thanks Received:
    1,260
    Essex
    Country:
    you say you have power to the timer has it a digital display ?
    what happens if you select constant on the hw/heating rather than timed ?
    give us some info on the system etc.
  4. BrianCopper1
    BrianCopper1
    26 Mar 2011
    8
    Thanks Received:
    Lancashire
    Country:
    Hi, thanks for quick reply I have put timer on constant still nothing. The timer is a Danfoss 102es timer linked to an old satchwell internal thermostat in lounge. All this linked to an old but reasonably reliable Baxi boiler.
  5. seco services
    seco services
    3 Dec 2007
    15,701
    Thanks Received:
    1,260
    Essex
    Country:
    when you put it on constant does the heating pump run ?
  6. BrianCopper1
    BrianCopper1
    26 Mar 2011
    8
    Thanks Received:
    Lancashire
    Country:
  7. PEDANTICVINDICTIVEMAN
    10 Jul 2004
    13,090
    Thanks Received:
    2,750
    Country:
    oops missed the first bit, yea check room stat is switching
  8. BrianCopper1
    BrianCopper1
    26 Mar 2011
    8
    Thanks Received:
    Lancashire
    Country:
    room stat seems ok it is making the clicking noise that usally kicks boiler in but limited knowledge on this front!
  9. Beerlover
    Beerlover
    7 Sep 2010
    1,072
    Thanks Received:
    210
    London
    Country:
    Is your boiler fan flued by any chance? If this is the case the fan normally runs on low spped to cool the effect of the pilot. With no power the overheat stat may have tripped.
    Job for a RGI if it is located in the combustion chamber (get it serviced at the same time). Check for an extrnal reset button first though. ;)
  10. Sponsored Links
  11. bengasman
    bengasman
    28 Jan 2005
    34,181
    Thanks Received:
    3,124
    London
    Country:
    How do you know that it is done correctly?
    We are engineers, not soothsayers; you need to give much more info.
  12. Googlyhead
    Googlyhead
    26 Mar 2011
    35
    Thanks Received:
    3
    Country:
    That's just the switch clicking on and off (mechanical, not caused by electrical 'flow'). IMHO you need to find if any of the heating equipment is getting power.
    Does anything have a display or light? Presumably the old pilot light keeps burning without power, so that's no indicator.
    Checked the consumer unit (if there is one, and there's a heating switch / fuse there) as well as the spur you looked at? I'm presuming you're neither an electrician, nor have access to a multimeter?
  13. Agile
    Agile
    26 Jun 2004
    64,039
    Thanks Received:
    4,595
    London
    Country:
    That senario usually means that an engineer is going to be required.
    An independent is usually cheaper as they dont have shareholders.
    Tony Glazier
  14. Googlyhead
    Googlyhead
    26 Mar 2011
    35
    Thanks Received:
    3
    Country:
  15. BrianCopper1
    BrianCopper1
    26 Mar 2011
    8
    Thanks Received:
    Lancashire
    Country:
    got a light on control unit which turns CH / water on and display still working. not sure how to check if room thermostat is ok I do have a new one should i fit it and see?
  16. bengasman
    bengasman
    28 Jan 2005
    34,181
    Thanks Received:
    3,124
    London
    Country:
    I've tried runes, tealeaves, Ouija boards, I-Ching and crystal balls; I'm crap at it and need to able to read what the installation consists of and what is happening..
  17. picasso
    picasso
    8 Apr 2008
    10,641
    Thanks Received:
    2,673
    Essex
    Country:
    what model of baxi do you have?, do not start guessing you will only make things worse.
Loading...
Share This Page
