Electrical shower with intermittent low pressure
19 Mar 2012
Cheshire
I have a Mira electrical shower which we inherited with the house 5 years ago. It worked fine until a year ago then the low water pressure light would randomly come on and no water come out. It resolved itself bizarrely but a few weeks ago it started doing it again. Sometimes it will work for a minute or two, then stop working. Other times the low pressure light comes on immediately and it dribbles a few drops of water and nothing else. Please can anyone suggest what might be wrong with it please?
Sounds like you have a solenoid coil related problem
Could be just the coil at fault or pcb, would need some tests run on the shower with a multi meter.
What mira is it ? will make fault finding abit easier.
i have the mira sport sometimes i have same problem which can be fixed by removeing the cover power off first turn off water remove in line strainer & clean job done
Thank you for your post. That seems so straight forward! However I can't tell where the in line strainer is...[/img]
Turn off power
Turn off water
Remove cover
Look for hexagon plug head (white or black plastic cant remember)
unscrew anticlockwise
pull out & clean strainer
& don't over tighten when reassembling
I can see one thing that is hexagonal but it looks like copper not plastic. It's about a 50p in size. Would that be it?
you may have an older or newer shower no harm in trying to slacken it anyway havent had the cover off on mine for a while but think it was a 24 - 27 mm spanner i used
