I have a 1940's property whose existing supply is overhead, entering the roof/loft on one side, traversing the width of the house, exiting other wall and is clipped onto the rendering dropping down to 4ft and entering wall to the main fuse/FCU.
I have planning permission for an extension on the side the cable is clipped and as part of the works will be having a complete re-wire since existing wiring is old rubber sheathed and hence out of date.
Currently the existing roofspace is poorly insulated, and supply cable merely lays across roof joists and am concerned that potentially insulating to current regs would cause heating and derate the cable.
The extension will involve a lot of groundwork - e.g gas meter will have to move and the existing understair location of the main fuse/FCU is not ideal and am wondering if it would be sensible to plan to have the supply re-routed underground (the supply pole is at the end of my drive)?
The cable could then enter the extension in the front of the house adjacent to the front door where the main fuse and FCU could potentially be located.
All of the building works is notifiable, however I am asking here 1st because my architects drawings didn't detail any of this and my builder's quotes most likely don't include this since I assume they I will most likely sub-contract the electrics out.
Really I just want to know what my options will be and hence get quotes/budget accordingly,
Ed
Ed
