Hi, can any body tell me the requirements under Part 'P' for electrics in a new en-suite to satissfy BCO.
Thanks.
Thanks.
It doesn't have to.It has to comply with BS7671:2008.
It's not the 16th/17th that is the issue - there is no requirement in the Building Regulations to comply with any edition of BS7671.OK agreed as BAS says the Part P document has not as yet been altered to say BS7671:2008 rather than BS7671:2001 but if the LABC were asked to oversee the work under Part P I would not expect they would accept BS7671:2001 any longer.
1) There's no requirement to work to BS7671 so therefore there's no requirement for an LABC to be able to I&T to BS7671.That is of course if the LABC do the inspection themselves anyway as I understand there is only one Council with a qualified building inspector able to sign off work. Think someone said it was Leeds?
They would have to do the I&T to BS7671 - that's not the same as saying that the installation has to be found in compliance with it, as the only thing you need to do to comply with the law is to make reasonable provision in the design and installation of electrical installations in order to protect persons operating, maintaining or altering the installations from fire or injury.And where the LABC employ a contractor to oversee work they would likely be signatory to one of the overseeing bodies and would have to comply by their rules as well so would be working under BS7671:2008.
It is the most sensible route. You do still need to maintain an awareness of the 16th though as the actual law regarding notification still refers to that.So in real terms one does have to follow BS7671:2008
Since P1, which defines what you must do, doesn't refer to BS7671, then this is irrelevant.But Part P can't refer to any documents which have not been published in Welsh and has itself also be published in Welsh or it would break the law to be in force in Wales and if it breaks a law it can't be law it's self.
Make your mind up!!!!!!!It is the most sensible route. You do still need to maintain an awareness of the 16th though as the actual law regarding notification still refers to that.
