On building an extension, I opted for cold roof and in order to gain max thermal performance decided to not run electrics for spotlights. Now I need to add lighting such as LED track lights, is it possible to run the cable ontop of the celoxte under/in the plasterboard? The plasterboard is screwed directly onto the celotex therefore assume I need to remove a channel in the plasterboard and run the cable in conduit then skim over the top.
Is this feasible how much air gap would be required or conduit? The run is quite small to the light around 30cm or so.
