What's a newly installed 13A supply?
Do you mean a newly installed socket circuit?
If so, probably not.
I wouldn't have thought so - even 7.5kW one are only marginally 'fit for purpose'. I suspect that something is wrong here!Having said that a 3.2kW shower isn't going to be much good. Are there such things?
We had a supply put in for a 3kw shower but have now found another that uses 3.2kw and were hoping it would be ok to run this instead.
Before we all get confused. What exactly is it that you want to install (make and model number).
Not a lot - at least, not for me! As previously asked, do you know the make and model number?Sorry, I think I have confused you all. The shower is a mains water pressure unit. the electric power of 3.2KW is purely to run some LED lights and a steam generator as it is a steam shower unit. The shower manufacturer states it uses up to 3.2kw and requires an appropriate supply to meet that requirement. does this help
Kind Regards, John
What's the rating of the MCB for this circuit, and is it RCD protected?
