    Dismiss Notice
Emulsion paint peeling off back to plaster when sanding
Discussion in 'Decorating and Painting' started by Frednewton, 23 May 2020.
  1. Frednewton
    Frednewton
    19 Mar 2020
    5
    Thanks Received:
    Country:
    Hi, am lightly sanding an emulsioned paint wall prior to repainting, but the paint keeps peeling off right back to the bare plaster. I've now got a huge area without sound edges. House is 1989, probably two previous coats on the wall. No damp. Any tips, please?
  2. Sponsored Links
  3. sparkwright
    sparkwright
    20 Aug 2009
    7,830
    Thanks Received:
    965
    Dorset
    Country:
    Sounds like a mist coat wasn't applied in the beginning to the bare plaster.
    You can 'fill' then sand the bare patches to get it reasonably flat, but applying the new paint COULD cause some of the old paint to bubble up.
    All bare plaster and filler should be primed with a diluted matt emulsion.
    Some experimentation will be required, to see if the old paint decides to lift, so watch how it goes before you apply the final coat.
  4. Frednewton
    Frednewton
    19 Mar 2020
    5
    Thanks Received:
    Country:
    Thank you for your advice. I did exactly as you suggested and it has worked fine.
  5. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
