The hot water cylinder can be DHW tube or CH tube, don't need to have a pressurised tank needing a yearly inspection. This
is a silly price to install, so not saying go down that route, but I like having a hot water cylinder so in summer I can use solar to heat my domestic hot water.
Electric prices were tied to gas prices, it is anyone guess if that will continue, so we know electric is more expensive to gas, and as a result we have for years heated DHW with gas, but as soon as we get solar, batteries, storage heaters or an EV, we also start to look at cheap overnight electric, and then heating DHW with electric becomes a lot cheaper than with gas.
Back in mid 80s I fitted a shower using water from the boiler, and there is no question, a shower using water heated by the boiler, either direct or with a storage tank is better.
However, this house already had electric showers, so they have remained, and they work well, I would assume because the rose is matched to the shower, but it is simply not worth the effort to change them to fed from DHW. Since cold water tank in loft, and showers on the ground floors, there would be loads of pressure, but would cost too much to get the pipe work installed.
I have used a power shower, and yes very good, could actually wash the ceiling of the wet room with it, but was not permitted with a combi-boiler, so had to be swapped for a mixer shower.
I don't want a combi-boiler, all they are is a small tank crammed into the boilers casing instead of having a large cylinder, at least with oil, and we would loose the option to heat DHW with solar or off-peak.
