I
ImayKnow
I have a mains cable that runs from the house into the garage.
In the garage it is just pinned to the wall with cable clips but I wish to now enclose it in 20mm diameter plastic conduit. Two questions I have are:
1) how far apart should I put the spacer bar saddles, and where should they be positioned? (I will have a few 90 degree elbows, a three way tee and a couple of 1 way terminal boxes (which I was planning to drill at the back where the cable comes through into the garage, and goes back into the house at the end of the run)). The total length of the run will be about 8 metres.
2) how do I drill the existing plastic surface boxes (one by 1G and one by 2G) to accept the male adapters into which the conduit will enter them??
