C
cb9002
I was going to use some end feed to iron adaptors like these:
but was thinking... they would have to be tightened onto the fitting before the pipe was soldered in - wouldn't the ptfe/jointing compound get damaged by the heat? What do you use?
I know using a compression adaptor would work but I'm trying to avoid that as I'm tiling over the floor space which the adaptors will be in.
Thanks.
Thanks.
