Enforcer wireless alarm
25 Nov 2021
Recently had an enforcer wireless alarm set-up. After my mains being out of action (smart meter installation) I can no longer turn my front door chime off. Regardless of whether the 'c' is displayed or not the chime continues to sound. Is this something I can sort myself?
Are u pressing c on the main control panel or an arming station/keypad?
Has the system been completely down powered as in the battery drained whilst power off
The mains was down for around 30 minutes, still operating on battery power as far as I’m aware when it went back up and everything else operating as normal apart from the chime not turning off.
I’m press C on the main control panel.
Try fully power cycling the panel so main off and battery out and see if the chime sorts itself out for you
I was thinking of trying this too. However, before doing this do you know if this will keep all my prior settings or will it require a further engineer set-up?
