    Dismiss Notice
Engineered or Solid Wood for Kitchen
Discussion in 'Floors, Stairs and Lofts' started by SamCo, 8 Jul 2019.
  1. SamCo
    SamCo
    7 Jul 2019
    14
    Thanks Received:
    Country:
    Hi we have just completed the kitchen renovation apart from the floor. My girlfriend would love solid wood flooring but I have heard they don't do well in moisture prone areas.
    I saw a guide saying that engineered wood might be a better option but I am still cautious of water warping the planks. Does anyone recommend either? I don't like the idea of LVT because the floor may need to be accessed for pipe work in the future.
    Please help..
  2. foxhole
    foxhole
    14 Mar 2006
    13,765
    Thanks Received:
    1,464
    Kent
    Country:
    Personally would not use timber for kitchen flooring .
  3. SamCo
    SamCo
    7 Jul 2019
    14
    Thanks Received:
    Country:
    What would you choose? LVT?
  4. Notch7
    Notch7
    15 Sep 2017
    9,693
    Thanks Received:
    851
    Sussex
    Country:
    if you want access, that means a floating floor. a floating floor means engineered not solid. Some engineered timber floors have a click system that hold them tight together like laminated.
    tell your girlfriend engineered flooring is solid wood flooring -there is no difference in respect of how it looks, the top layer is solid wood and can be sanded / repaired as much as a solid wood -assuming you but the 20mm thick stuff with a 5mm or more face.
    dont even think about a solid flooring unless you can nail it down, the amount of movement in solid is too much for floating.
    • Like Like x 1
  5. SamCo
    SamCo
    7 Jul 2019
    14
    Thanks Received:
    Country:
    Thank you Notch, great answer
  6. dazlight
    dazlight
    6 Apr 2012
    1,199
    Thanks Received:
    166
    Merseyside
    Country:
    Have a look at Quickstep laminate as some of the ranges have a waterproof top. Like impressive and majestic
  7. SamCo
    SamCo
    7 Jul 2019
    14
    Thanks Received:
    Country:
    Thank you. Funnily enough I phoned up Lifestyle Flooring UK in Leeds and they recommended the same. Quick-Step Impressive looks fab
    • Like Like x 1
  8. crazydaze
    crazydaze
    30 Oct 2009
    904
    Thanks Received:
    135
    Surrey
    Country:
    Engineered will be fine but be aware of the surface coating, it is this which will define how practical an Engineered is in any area. A Laqcuered finish means you walk on a coating that will not need waxing,oiling or polishing and is wipe cleanable, it's also resistant to staining and water marks from spills. UV Oiled finish means you walk on the wood itself rather than a coating, there is some extra protection to the oil and you can oil scratches etc as a repair if you need to. A Oiled finish is very difficult to maintain, not unlike putting a solid kitchen work surface on the floo and walking on it. It will be the least practical finish to live with and will require regular maintenance to keep looking its best.
  9. SamCo
    SamCo
    7 Jul 2019
    14
    Thanks Received:
    Country:
    Will the second product here https://lifestyleflooringuk.co.uk/engineered-wood-flooring be suitable for the kitchen?
  10. crazydaze
    crazydaze
    30 Oct 2009
    904
    Thanks Received:
    135
    Surrey
    Country:
  11. SamCo
    SamCo
    7 Jul 2019
    14
    Thanks Received:
    Country:
    Thanks for your advice mate. I have found one that the girlfriend and I agree on. We're going to go for the
    190mm Pearl Satin Lacquered Engineered European Oak Wood Flooring 14/3mm Thick
  12. crazydaze
    crazydaze
    30 Oct 2009
    904
    Thanks Received:
    135
    Surrey
    Country:
    That sounds good.
    Remember, never wash wood floors to clean them, all you need to do is sweep, hoover or use a spray cleaner for lacquered floors and a microfibre cloth. Woods Good and Bona are two manufactures of decent floor cleaning product, there are many others too. Mopping a wood floor will kill it. In addition, use felt pads under chair feet etc.
    • Like Like x 1
Loading...
Share This Page
