Depends also on the backing used, so thinner is not always better.The thinner the board, the faster the heat transfer,
28 degrees is what our manufacturer of the duoplank states to be the maximum surface temperature (Oak range of duoplank is guaranteed on UFH, if the UFH is used correctly of course).The statutory limit on the floor surface for health reasons is 30 C ( or poss 28 , don't recall ) and by imposing your limit , you are significantly diminishing the W/m2 output.
The surface temperature of the finished floor must never exceed 27°C at any point. This also applies under rugs, etc., and furniture. Provided that rugs are not too thick, or there are...........
standard requirements and conditions throughout the wood flooring industry. Check with any wood flooring manufacturer
who specifies this interface temperature ?any wood flooring manufacturer
