hello, im wondering if anybody could help me. I’m planning on doing some DIY in my kitchen. I got a cupboard underneath the stairs but the door on it is quite short so I have to duck down each time I have to get something. What I would like to do is make the opening higher only for around 30cm which would leave 40cm to the celling or 30cm if I take into consideration concrete lintel of 10cm height.
I think the wall is load bearing as I can see there is a wood beam sitting on top of the wall and floor joists slot into it. I attached few pictures. My question is as I would like only to make it slightly higher do I need to support the celling and the joists if I decide to cut the wall and insert a lintel. The wall itself is built of grey blocks. Not sure what type they are. I wouldn’t cut the wall any wider only 30cm higher + 10cm for the lintel. Any help would be appreciated. Thank you
