Enterview 4 - power supply issue
20 Apr 2005
Gloucestershire
Hi
I have an Enterview 4 that I'm powering from a Elmdene PSU with battery backup - the output is around 12v, but the monitor doesn't work (I only get a blue screen, which I believe is due to a power issue)
I can put the original Enterview PSU back in to service, but then it won't have a battery backup, is there a way around this?
Additionally, I'm trying to have an output from the unit to open an electric gate - is this possible?
Try the psu first , normally a blue screen is a sign of no video input , check the camera.
I've checked the connections and doubled up the power connections, I've also reinstated the original power supply and I still get a blue screen, can I check that there should only be one PSU and that there's only 4 connections plus the power at the monitor station inside?
Ok, I've re wired it again, and now the speaker inside is screeching, I'm beginning to think it's broken, which is a pity as it's around£250!
It was working before I moved it, it was on really thick outdoor style alarm cable. I've rewired it internally on a short piece of CAT6 and it's squealing and making a right row!
Current capacity of thin cable, it may be screeching if too close handset/ entrance station feedback
Thanks sparkymarka, I've managed to fix it - two broken cores, either faulty/damaged cable or burnt out?
My next problem is trying to get the intercom to open the gates, I've connected a piece of wire to the OPEN terminals on the gate, briefly shorted it out and the gates open, however, when I wire these to the NO and COM connections on the intercom it causes the gates to open, then jam in the open position, any ideas?
Here's some pics of the connections:
The gates:
The intercom:
[/img]
Check for voltage at lock release terminals on door station it may not be a voltage free contact
I've checked and I have 0.03v normally, and 0v when the code is entered, I also get continuity when the code is entered for approx 2 seconds - it's driving me mad! There must be a way to get it work :(
On dc range between com and nc. And between com and no.... I can't see from picture what you have in the terminals !
Do the gates work ? Or are you trying to get them to work with this unit ? Just that a lot of gates the stop input is normally closed input , so you have to link it out ! This may not be the case with your gate.
Just a quick update, I've installed the relay, and corrected the wiring issue with the thanks to a new power supply from ESP, and all is good!
Thanks for your help
