R
RWDave
I have made some guides that id like to share with the DIYers here, as EPDM is becoming more and more popular i thought it might be beneficial for you guys to learn the basics of laying EPDM.
I hope some of you dont feel like im teaching you to suck eggs, this is purely for the less experienced DIYers/Roofers.
I will start with Roof Preperation and see what people think, i have many more guides that i can post if people find it a good read. Future guides have images as they go along.
The products i use are Firestone EPDM products for reference.
I hope this helps.
Material storage and handling
• It is vital the roofing contractor is aware of correct storage of roofing materials. The following are some storage recommendations for handling these products.
• Read labels on all adhesive, primer and sealant tins.
• Keep all glues, adhesives, sealants and cleaning products away from ignition sources such as torches, naked flames, fire, sparks, etc and DO NOT SMOKE in the vicinity of these products.
• Do not breathe vapours and maintain proper ventilation in storage areas.
• Post “No Smoking” signs close to areas where these materials are stored.
• Keep the products in a cool and dry place, and out of direct sunlight.
• Keep container lids closed when not in use, due to loss of solvent through flash-off. Open containers must not be placed near any intake ventilators.
• ALWAYS Stir adhesives and Quickprime plus before and during use. If exposed to temperatures less than 10ºC, restore the Quickprime plus, adhesives and sealants to room temperature prior to use.
• Extreme warm weather can dry out the solvents in adhesives and Quickprime plus quickly. Protect the pails by installing a piece of insulation board under the can on hot summer days and cover cans with a piece of membrane.
• Never use a naked flame to "speed up" the drying process of adhesives or Quickprime plus. Always allow to air dry only. Heat guns may be used to mould Quickseam Formflash. Take care not to over heat.
• Protect all rubber products from discharges such as petroleum products, greases, oils (mineral and vegetable), organic based solvents, animal fats and fresh bitumen (less than 4 weeks old). Do not use materials that have been damaged to the point that they will not perform.
• Protect the EPDM system from direct contact with steam or heat sources when the in-services temperature is in excess of 82ºC.
Tools required
• 2-inch steel or silicon hand roller
• Penny roller
• Stiff broom
• 9-inch paint roller frame & several medium nap, solvent compatible roller covers
• Safety glasses and eye cleaning solution
• Mastic gun
• Crayon
• Screw gun and hammer drill
• Hacksaw and blades
• Solvent resistant rubber gloves
• Stir stick for adhesives
• Tin snips
• Scissors
• Measuring tape
• Hammer
• Duct tape
• Chalk line
• Cotton rags
Product information
EPDM (Ethylene-Propylene-Diene-Terpolymer) was first introduced in 1962 and commercial production began in 1963. The first EPDM roofs were laid in the late sixties. It has a great track record of success in the flat roofing industry, due mainly to its virtually unlimited ozone and weather resistance and low temperature flexibility.
Today, over a billion square metres of EPDM roofing membranes have been installed worldwide from the frozen weather conditions of Alaska to the scorching desert climate of the Middle East. This track record demonstrates this material’s capabilities and its rightful place as a successful solution within the roofing industry.
Rubbercover EPDM is a synthetic rubber roofing membrane used for flat and low-sloped roofs. It is available in a variety of sizes from 3m x 7.62m up to 9.15m x 30m with many size options in between.
Weather conditions
There are a few points to consider in order to achieve a quality installation when weather conditions are inclement.
Care should be taken when using adhesives, sealants or Quickprime plus in cold weather conditions (below 10ºC). It is necessary to store these products at room temperatures prior to use. Do not allow water-based bonding adhesive to freeze.
If temperatures are likely to fall below freezing in the first 48 hours after application, do not use water-based bonding adhesive to adhere the membrane. In this case, solvent-based bonding adhesive should be used instead.
Certain combinations of temperature and humidity may cause condensation to form on the surface of the membrane. If this occurs, stop the operation and wait for better ambient conditions.
The installation and positioning of large EPDM membranes may be difficult in windy conditions. Prevent any wind getting under the sheet during installation. If necessary, use a temporary ballast to keep the membrane in place until it can be fully secured to the substrate.
Substrate considerations
The underlying substrate of the roof should be in good condition, with no rotten timbers. All decayed and wet timbers must be replaced.
Standard 18mm OSB3 or plywood is laid at right angles to joists. A 3mm gap is necessary to allow for expansion and contraction.
Self-drilling countersunk screws shall be used. Under no circumstances should nails or staples be used for fixing of a timber substrate. These fastenings are inclined to work loose and risk damaging the membrane.
The substrate finish should be smooth, and free of sharp edges, wood splinters, etc. All rough surfaces that could damage the membrane should be isolated or removed.
The roof surface must be dry, as moisture will cause poor membrane adhesion and blistering.
All surfaces areas should be swept to remove debris, dust and other loose particles. Once the roof has been prepared properly and has a clean and dry substrate, the EPDM membrane can be laid in-situ ready for attachment.
There should be a minimum finished fall of at least 1:80 to provide positive drainage.
You can find all my guides on PDF Deleted
(I know there are rules on posting links when you're new to the forums, please just inform me if this is not allowed)
I will post the next proccess of EPDM installation next week some time
Thank you.
I hope this helps.
Tools required
• Penny roller
• Stiff broom
• Mastic gun
• Crayon
• Tin snips
• Scissors
• Measuring tape
• Hammer
• Duct tape
• Chalk line
• Cotton rags
Product information
Weather conditions
Thank you.
