I have a window (wooden framed casement) that is of the correct opening dimensions for an escape window but the regulations state that it should be between 800and 1100mm from ground level. Unfortunately it is only 720mm from the ground level so what has been suggested is that I have a window opening limiting device that can easily be removed in the event of a fire. I have goggled such a devise without luck.
I was wondering if the simple window stay at the bottom of the window would suffice, after all it does limit the window opening and it is easily removable in the event of a fire? If not does anyone else know of such a devise and where I might get one?
Thanks.
Thanks.
