I have an escort van (S reg) and the battery keeps going flat, the battery is fine (although I now have 2 to keep one full) and the alternator has been checked as is fine.
The battery will be good for a couple of days, then need changing and the battery re-charging.
I want to check if there is somthing draining the battery when the engine is off, can I just connect a multimeter, on amps setting between the +ve of the battery and the +ve battery lead?
