You should at least be able to work out what materials you'll need.. e.g. There's about 10 concrete block per sqm of wall. Multiply by the wall sizes. That's your block count.. blocks are about a quid each..
Then do he bricks you like
Then plasterboard, approx 2.5sqm each (its more but that gives a good margin for wastage), and a fiver each.
Should be able to price most stuff off
Wickes website, or screwfix.. they even sell stuff like bifolding door sets. Glazing is 100 to 300 quid a sqm depending on your spec, pvc, alu, triple glazed etc
Having totalled up all the materials you'll need, add 25% to cover things you've forgotten, like screws, glues, trims, etc..
Now double the amount - that's probably the price "oop norf". Now add 50% again - that's probably the price "darn sarf"
Some jobs cost way more for the install than the materials, some way less. My timber frame was 26k and erection 13k. My plaster was 1k and install 4k. Overall it works out between double and triple the material cost, for building a house.. extensions are disproportionately a little more; John's southern extension is about 3.5k a metre, my northern new build is working out about 1k/sqm at the moment, but I've done most of it myself so that's broadly a material cost and my time rated at 0
