I'm trying to help a friend with planning permission on a bungalow she is thinking of buying. So far planning with is not going as hoped because the LPA don't like some of the proposals. Finding a solution is urgent so as not to hold up the purchase.
It may be that she drops the planning application and resorts to Permitted Development but the bungalow may be on a corner plot and we understand that there are restrictions to the PD rights for corner plots. However, there is an electrical sub-station that also occupies part of the corner plot and the local council planning are divided as to which actually occupies the corner plot, see attached drawing.
The legislation (?) covering this can be found at:
https://assets.publishing.service.g...der_Technical_Guidance__-April_2017_FINAL.pdf pages 14-16 but it is not clear cut. The guidance explains that the extent to which an elevation of a house fronts a highway will depend on various factors, including 'the distance between the house and the highway - in cases where that distance is substantial, it is unlikely that a building can be said to front the highway. The same may be true where there is a significant intervening area of land in different ownership or use between the boundary of the curtilage of the house concerned and the highway.' It doesn't state what that distance is or what constitutes 'significant intervening area of land'.
If anyone can help with this I'd very much appreciate it. I've searched the internet for similar situations but found nothing. Ideally a pointer to some sort of legal case or lawful development certificate decision would help.
Edited 20:17 18/7/2018
