- Joined
- 27 Jan 2008
- Messages
- 29,889
- Reaction score
- 3,722
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
Many many years ago Flounders and Swan summed it all up in their song.
"The English, The English, The English are best, The English are best and to hell with the rest."
Not saying I fully agree as a Welsh man but to try to persuade the British that some other system is better than ours is really going to be hard.
There is room for improvement the sockets could be made so radials in 6mm cable would be possible and still have the odd spur. However since any system we compare to is limited to 16A there is no other system that is better for allowing distribution.
To have FCU which are over 13A would also be handy but even abroad not really seen anything which we don't have.
We were behind the rest of Europe as to fitting of RCD's maybe because our system was safer anyway? And it could be argued that using RCD's means shuttered sockets are not so important. However I have had nasty belts for RCD protected systems and I would consider shutters are a good idea.
The same argument as to isolation transformers and RCD protection in bathrooms I realise the transformer does mean the RCD does not protect and there may be a case for RCD rather than transformer protection but considering the transformer also limits current to 20va I think one would be hard pressed to fight that case.
Yes the 13A plug does sometimes fail to take 13A without over heating but with the selection of near same plugs and sockets in Europe which either strain or do not have good contact they are no better.
The whole idea of having a non earthed socket into which a plug with earth connection can be inserted must be the craziest system ever considered.
So it seems there has been little change since the song was written! Sometimes others do have good ideas like Australian plastic bank notes but lets face it most of them came from here in first place. And the whole idea of having all bank note denominations the same size must be as crazy at doubling the current in the system by using 110 volt?
