They aren't, but any DIY manuals they consult will assume that as the basis for the installation, so one which matches a foreign standard will end up less safe for them to work on.How many unskilled users of domestic installations are familiar with BS7671 then?
Those would be reasons, i.e. based on logic.Who would be installing to any other standard for no reason? There's bound to be some reason for wanting to adopt that standard: The German guy presumably wanted Shucko sockets to use German appliances he brought with him; I would install NEMA outlets because of the amount of 120V equipment I have, and so on.
If you have no reason then you would be acting unreasonably.
It matters because if you are acting without reason then your actions are unreasonable and therefore unlawful.But how would anyone else know your reasons? What does it matter?
If a court were to decide that you had not acted reasonably then you would find that their opinion mattered a great deal.The issue is whether your installation standard meets the requirements of the Building Regs., not whether you could have installed to some other standard, or whether anyone else considers your reason good enough or not.
There is no official documentation which says that you have to install to any standard.Please show me any official documentation which says that you must install to BS7671 unless you have some good reason (however that may be defined) to do otherwise.
But if you decide that you will work to a standard, and without reason you choose one which is less safe than another one you could have chosen then you have not acted reasonably.
