What is it you actually want to achieve?
Nothing...I just wanted to know if it was permissible and this has been answered by ericmark
I know of one person who persuaded his BCO to accept German regulations as an alternative, so that he could have a socket in the bathroom.
In general, you would have to have the gift of the gab to get this agreement though.
In theory it could be that certain european standards may allowed if Building Controls consider them to be relevant.
So its a no and yes from me.
However having seen some of the other German ideas I am glad we don't. They use conduit without bends and fit plastic end caps and free air from one length to the next with no earth bonding between each length. They were quite upset when it was pointed out they could not do it here.
I did see a set of houses wired with split phase 110v supply in Suffolk originally for US military there must have been some arrangement for that but that is the only one.
Why should you have to? There is nothing in the Building Regs. which says you must follow BS7671, nor any other specific standard. However it seems that building inspectors seem to like to use the Approved Documents as their absolute guide, despite the fact that they are not law, and the guide for Part P clearly states that following the standard of another EU/EEA country would be one method of showing compliance.
Absolutely. However, what you do have to have is the work signed off by the BCO. If they decide to be awkward, then you have to choose between doing what they request or taking them to court (or whatever the procedure might be). Most people will settle for a quiet life, unfortunately.
And there is the slight issue of being able to convince the court that it was reasonable for you to install to a different standard.
Thanks.....I though that the latest IEE allowed the installtion of a socket in a bathroom with certain provisos??
Do you really think that a step-by-step approach is going to do anything than become a step-by-step exposition of the idiocy of your position?You seem to be the one trying to pervert what is written into something quite different.
Let's try a step-by-step approach:
If it is not reasonable to work to something other than BS 7671 then you have not made reasonable provision for safety etc.
It may in some circumstances be reasonable to work to VDE 100, for example the case where that guy wanted a German socket in his bathroom, but if you are doing it on a whim then your basis for doing it is not reasonable.
On the contrary, we are talking about exactly that. In a domestic environment, i.e one where you KNOW that the installation will not be under the supervision of a skilled or instructed person then it is less safe to do it to a standard which will not match the information readily obtainable by unskilled and uninstructed persons wishing to operate, maintain or alter it.We're not talking about what you, I, or anybody else consider to be the relative safety merits of BS7671 vs. VDE-100, NF C 15-100, or any other standard
So if for no reason you do it to such a standard then then you have not acted reasonably.
