Today I replaced an upstairs radiator with a smaller model. Old one was a decrepid - approx. 1000mm (W) x 700mm (H) and the new one 600mm(W) x 450mm (H).
All appeared to have gone OK. TRV valve on the new rad seems to work OK and no leaks in the rest of the system. However, I've just found a leak from what looks like an expansion release valve that comes from a T-joint on the outlet pipe from my hot water cyclinder. (I think it's the outward flow as it connects into the cylinder just below middle of the tank and there's another one directly below it near the bottom.)
The hot water cylinder is a an indirect type. I assume the system is gravity fed and the boiler is a Potterton Max condenser.
Can anyone help me? or even explain why this might be happening.
