Had an unvented cylinder fitted about 6 months back - there was a long winded thread on here about it as the fitter stuffed it up in numerous ways and didn't issue paperwork. Got the problems sorted by him and received a Gas safe cert for it in the end...
Not sure if this makes any difference, but on the 'multi function' valve that does the pressure relief and pressure reduction etc, there's a separate connector for the expansion vessel that is blanked off (second one down on the right), and the expansion vessel is actually teed into the cold feed from that valve to the cylinder (the 22mm tee going off to the left).
Does this make any difference to anything? When I turn the hot tap on for the first time, there's a big burst of pressure that calms down after a few seconds, could this be due to the expansion vessel being connected in the wrong place? Of course if it's perfectly fine I'll ignore it and carry on
