Another thing I don't understand is what temp you set the BOILER radiator temp dial to - maximum 75 degrees?
Sounds more like yet another Vaillant install where the installer hasn't bothered to range rate the boiler![]()
You misunderstood me entirely.
That was probably 3/4 imperial pipe ...which dates your pipework to early/mid 70`s @ the latest- cuz that`s when it changed to metric[quote
I do recall the plumber moaning because he had original 18mm pipe to join to about 2 metres away from the boiler. But every time I lifted the floor to fit new rads upstairs I just saw 15mm
