Expert Advice Please
10 Mar 2008
Essex
I have just lowered a hall ceiling in a flat for a client. They have got massive ceilings and want it lowered so that they can board it out and use it for a small loft. I was just about to board it out when they asked if they could have spotlights put in it? I am a plasterer so am not sure how this all works so i thought i would ask a spark to get them some good practical advice The hall is only a metre wide and 4 metres long.
Any help would be really appreciated
Creating a loft is not the same as lowering a ceiling - I hope you got building regs approval, and did all the structural stuff properly...
And talking of Building Regs, the new electrical work will require approval, so you/your client will be needing an electrician anyway, so best to give the problem(s) to her, as she'll be able to see the place and sort out what's needed far better than people on the internet...
yeah i did actually, not a novice mate.
I was only asking so they could get some advice before getting an electrician out, i am not going to do it myself!
Yes it is possible
If its a flat, she will need fire rated downlights
Hope that answers the immediate queries ;)
Thanks for the advice i appreciate it
I thought that it might be a bit dodgy especially if you are going to board over the top of them and i said you probably won't be able to put any insulation in between because of the heat. Is that true?
You're right, it isn't generally a good idea to put downlights/spotlights anywhere near loft insulation. While I don't doubt that it is fireproof and very unlikely to set alight, it will at best restrict the cooling of the light fitting and possibly cause damage to the wiring or short lamp life. The exception would be if you have a proper hood over the fitting, otherwise leave a good gap.
