I've got a Vokera Cpact combi boiler which is just over 12 months old but is under an extended warrenty. I had real problems with a fluctuating hot water temp. which was diagnosed as being caused by a inlet water flow regulator (???). THis was removed (looked like a tiny piece of plastic in the inlet bit where the cold water went into the boiler) and problem solved. However - I checked the central heating pressure yesterday and it was running at 3 bar. So I drained away enough to bring it back down to 1-1.5 bar. This evening the pressure has shot up again. I've repeated the process but what could be causing this? Does the CH water pressure increase because it is warmer outside? Would the flow regulator be required to prevent water unintentionally entering the CH system? Should I evacuate? Help!!!
