These are all rear feed shower bars, I understand how those elbow connectors will allow exposed pipes to connect...however this solution creates a problem of the riser bar being offset from the wall...
The elbows which allow for the bottom feed to the shower bar offset the shower bar from the wall, therefore the outlet feeding the riser bar will also be offset meaning the riser bar will require an extended fitting to the wall...
Do you mean the shower riser rail? The vast majority are a shower hose connection and won't be affected by the distance from the wall. Did you have a specific type of shower valve in mind?
