Hi All,
I am looking for some advice in extending the radial circuit in a room in my house. I've never extended a radial circuit before so I'd just like to check a few things.
I have done a diagram of the existing and proposed extension.
View media item 67651
I'd like to add 3 double sockets into a bedroom.
1 of the double sockets will power a desktop computer and monitor.
2 of the double sockets will be for either side of a bed, so will be used for a lamp etc.
The wiring in my 1965 house is a radial circuit which supplies both the downstairs and the upstairs. (There are 3 circuits in total at the Consumer unit, 1 for the lighting, 1 for the sockets and 1 for the cooker).
Firstly I'm going to tidy up the wiring where someone at some point has moved the socket. I then intend to run a new cable to the first double socket, onto the second and third and then rejoin the radial circuit using a junction box, which will be accessible under a trap in the wardrobe.
I'll obviously be removing the separate 3 individually wired spur (is that common?!) I also found a nice unsheathed earth wire in the socket, I guess different standards have applied down the years!
I just want to double check with regards the radial circuit does all the above and the diagram look ok? Also will it be 4mm I need to use for the cabling, or will 2.5mm be ok? Will a 30Amp JB be sufficient?
Thank you for your help.
Richard
Richard
