Extending an appliance cable
28 Mar 2011
Conwy
Hi all
I need to add about a metre to the power cable of a tumble dryer, so that I can dispense with an extension lead and plug the appliance directly into a wall socket. Could someone please advise on the safest way to do this?
I’m assuming that bog standard choc block connectors wrapped in tape are not advisable, and I’d prefer not to open up the back of the appliance and replace the entire cable.
TIA
Last time I looked (about ten years ago) Homebase sold nice little white boxes with two strain relief clamps and a choc block inside. That should do nicely.
I went to great lengths to put two sockets from independent supplies for the washing machine and tumble drier, however today my tumble drier draws just 650 watt so there was really no need. So it is down to the tumble drier type in use?
Any non inverter powered refrigeration unit on a single phase supply can be damaged with excess volt drop, every fuse will cause some volt drop, as will extension leads, but I have a feeling the refrigeration unit (heat pump) in my tumble drier is powered from an inverter, so volt drop not that much of a problem, and I would be happy with an extension lead.
However the non heat pump condensing drier tends to be high power over 2 kW, and for an extended time, so the regulations tell us "The load current in any part of the circuit should be unlikely to exceed for long periods the current-carrying capacity of the cable (Regulation 433.1.5 refers). This can generally be achieved by:
(ii) not supplying immersion heaters, comprehensive electric space heating or loads of a similar profile from the ring circuit
(iii) connecting cookers, ovens and hobs with a rated power exceeding 2 kW on their own dedicated radial circuit" so really a non heat pump condensing tumble drier should not be plugged into a ring final, the vented often has an option to run on just 1 kW which saves energy as well, but the non heat pump condensing tumble drier, so what is required depends on the drier load.
I use to have the washing machine and tumble drier on the same double socket for years, but it was a vented drier so only 1 kW.
You are already doing it the safest way by using an extension lead. If it ain't broke etc.
Thanks for that. The company providing the warranty for the tumble dryer advises not to use an extension lead, hence the question. They’re not suggesting that I’m invalidating the warranty by doing so, just talking about the possibility of overloading.
How about one extension lead plugged into a wall socket, a second extension lead plugged into the first one then the tumble dryer plugged into that? Pushing it a bit ?
A short, good quality, single-socket extension cable is probably as good as anything. That can then only feed the single appliance with no danger of overload provided the lead is rated for the full 13A.
2 metres seem to be the most readily available from the sheds although cpc farnell have 1m in their house brand https://cpc.farnell.com/pro-elec/pel00517/extension-lead-one-gang-black/dp/PL13972 (slightly cheaper in white). Doesn't state the cross sectional area of the cores, sadly.
I take the moulded leads off defunct washers and dryers and use those with a single 13A "rubber" socket to make my own high power, short, extensions for this sort of use.
Daft idea.
Make and model of dryer please. So more accurate and sensible advice can be given.
NB cutting the moulded plug off an appliance (to extend the lead) is more likely to raise warranty alarm bells than using a suitable extension lead to a wall socket.
Some makes of appliance sell different lengths of moulded lead that 'plug in' at the rear.
A few years ago, I had to pull my mum's Miele washing machine out. I hadn't realised how short the flex was and stoopidly, I didn't unplug it first. It went bang. Feeling guilty, and not wanting to use inaccessible extension leads, I decided to fit a longer flex. The original flex used uninsulated push on terminals. I tried cheap insulated female terminals but they didn't pass the tug test.
I wasn't sure what size I needed so I purchased several options from https://www.cablecraft.co.uk/ , I then had to source a decent crimping tool. I all in it cost me about £50... but on the upside, I have a lot of different sized crimps which I might never use...
Extending leads aside, I think it is no longer the case that cutting off a moulded plug invalidates the warranty.
Daft idea.
It’s a Beko. Not sure of the model but it was very cheap and is highly effective. It’s been in the garage for four years on a single socket circuit but I brought in indoors after remodelling of the kitchen gave us more room. The nearest wall socket is a double which is behind a cupboard and has an extension lead plugged in to power stuff on the worktop above. Initially and because of lack of mains cable length I plugged a second extension into that first one, but now I’ve removed the kick board, opened the little hatch inside the cupboard which gives access to the hidden double socket and plugged the second extension lead into that. All good now I think, and thanks for all replies.
