    Dismiss Notice
Extending beyond approved plans
Discussion in 'Building Regulations and Planning Permission' started by Overthemoon, 18 Jun 2020.
  1. Overthemoon
    Overthemoon
    18 Jun 2020
    4
    Thanks Received:
    Country:
    Hello,
    Our planning permission is approved to 4 m for a rear single Storey part double storey extension. We wanted it to be 4.2 m (27 cm extra) to be in line with the garage wall. Basically the architect (who is a friend) messed it up and our fault for not having checked it. My question is what error do the councils usually allow for length? Can we go the extra distance without having to resubmit? Thanks
  2. Sponsored Links
  3. tony1851
    tony1851
    23 Feb 2012
    10,030
    Thanks Received:
    1,512
    Manchester
    Country:
    Why not ring the planning department - they are the only people who would be able to give you the definitive answer.
  4. DevilDamo
    DevilDamo
    14 Jan 2010
    1,936
    Thanks Received:
    315
    Country:
    I’ve got a bit of d’ai ja vu. Have you asked this on another forum? (n)
    Your Planning approval is based on the Planning approved drawings along with the stated/approved dimensions. You should only build to what you have approval for and any deviation ‘could’ open you up to Enforcement action. Although that would be the LPA’s final move before giving you the option to re-submit for what you want to build.
    Oh and btw, that’ll be an increase of 0.3m, not 0.2m :D
  5. IT Minion
    IT Minion
    28 Jul 2018
    3,208
    Thanks Received:
    244
    Country:
    Did the diagram show it inline? If so then you're not changing the size, you're identifying that the measurement listed weren't consistent with the diagrams. Which might be better or worse.
  6. cdbe
    cdbe
    22 Nov 2009
    1,013
    Thanks Received:
    167
    Oldham
    Country:
    Mine was approved for 5.5m but is actually 5.6m so a small (especially in percentage terms) breach. I do worry a bit when you see these stories about people being made to demolish when it's an inch to big, but I suspect (hope)that this is just the headline and there are other breaches that are the real issue.
    Obviously it would be nice if the authorities published an acceptable tolerance but everyone would just add it on from the start, a bit like when the police hint that they rarely stop drivers doing 80 on the motorway.....
    • Like Like x 1
  7. mrrusty
    mrrusty
    1 May 2018
    493
    Thanks Received:
    103
    Country:
    On my recent passed planning application I put "all dims +/- 100mm." on submitted drawing. Not queried.
    • Like Like x 2
  8. tony1851
    tony1851
    23 Feb 2012
    10,030
    Thanks Received:
    1,512
    Manchester
    Country:
    The official government guidance given to local planning departments concerning enforcement states:
    'Enforcement action may not be appropriate for a minor or technical breach when no harm has occurred'
    Therefore there are two tests; 1. is the breach minor and - if so - 2. has it caused any harm (eg loss of light to a neighbour).
  9. johnny2007
    johnny2007
    11 Jan 2012
    2,874
    Thanks Received:
    436
    London
    Country:
    Some councils don't care, some others are strict.
    But for 20cm it's virtually impossible that they'll cause any trouble.
    Worse case scenario I can see is that they make you submit amended plans.
    But seriously, they have better things to do than bothering someone for 20cm.
  10. Sponsored Links
  11. Notch7
    Notch7
    15 Sep 2017
    22,453
    Thanks Received:
    1,574
    S. Uplands
    Country:
    IME no.
    "non material amendment Sir, start your application again from scratch"
    you can skin it whichever way you want, but it comes down to one thing: you would be building something not compliant.
    The risk of being found out is very very very small (unless you pizz off a neighbour), but you have the ever so slight risk of big hassle.
    planning officers never visit a site after consent (they barely visit it before), unless there is a complaint and they might then come around with a tape measure.
  12. Charlie George
    Charlie George
    16 Mar 2018
    645
    Thanks Received:
    78
    Manchester
    Country:
    On extensions of 4m, iv'e always built to 4060mm when using metric brick to suit brick length, seems universally accepted,
    as others have said you would be unlucky to be pulled.
    • Like Like x 1
  13. garyo
    garyo
    11 Apr 2006
    2,105
    Thanks Received:
    196
    Berkshire
    Country:
    This is the crux of most planning matters to me. Do you talk to your neighbours much? are they reasonable? are you reasonable? Would you be embarrassed to show them your plans over next Sunday's BBQ?
    • Like Like x 1
  14. A_Novice
    A_Novice
    29 Dec 2017
    292
    Thanks Received:
    7
    Country:
    Personally considering it's a rear extension and single storey I would just go for it.
    Might get shot down by other members but the council are too busy to come round and measure every extension built.
    Neighbours aren't going to stich you up as they won't be able to tell you breached the plans by 30cm while peaking through their curtains.
    Rules are bent all of the time regarding planning and I would consider this type of thing minor.
    • Like Like x 2
  15. Overthemoon
    Overthemoon
    18 Jun 2020
    4
    Thanks Received:
    Country:
    Thank you everyone for your suggestions so far. Really valuable input and has helped me clear my mind. Just need to pass the hurdle of convincing the builder now :)
    This is our first time ever with any home improvement project and don’t really have anyone in our circle who has done it before. So imagine I’ll be seeking your advice in the near future for other hurdles as well.
  16. DevilDamo
    DevilDamo
    14 Jan 2010
    1,936
    Thanks Received:
    315
    Country:
    Are your Building Regulation drawings based on the Planning, i.e. 4m and that is also what the builder has quoted for?
  17. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
