extending garage electrics
11 Dec 2011
Down
At the moment i have a small consumer unit in the garage with two breakers in it: one for the lights and one for the sockets. At the moment i have a double socket on the rear wall and a fluorescent tube in the middle of the garage. the house was built in 1999 and was up to code then.
what i want to do is add another double socket above my work bench, a single socket at the small freezer an extra fluorescent tube above the work bench and a sensor floodlight on the gable end
what should i buy any advice on how to go about it
Some questions;
Does a 30 mA RCD protect the garage supply, either in the garage or in the house?
What size MCB protects the socket circuit? (and the lighting circuit, for good measure)
Does a 30 mA RCD protect the garage supply, either in the garage or in the house? yes in the house cpc 4.mm, live 4.0 mm, fuse 30Amps is written in cu in house
What size MCB protects the socket circuit? (and the lighting circuit, for good measure) plugs cpc 1.5mm,live 2.5mm and fuse 15Amps and lights cpc1.0mm,live 1.5mm and fuse 5Amps
in the house cpc 4.mm, live 4.0 mm, fuse 30Amps ... plugs cpc 1.5mm,live 2.5mm and fuse 15Amps and lights cpc1.0mm,live 1.5mm and fuse 5Amps
Even if you don't post an answer here, please be honest with yourself. Do you actually, genuinely understand what that means?
hi
i am really only looking for ideas i would then have a friendly electrician connect it all up after i had run the wires the way he asked me to
You can simply extend from the existing socket, using 2.5mm to the next double socket and then onto the single for the fridge
Same goes for the extra light, just extend from the existing in 1.5mm. For the external light, you can take a feed from the board on the 5A fuse, through a switch if required, make the hole in the wall for the cable exit point directly behind the fitting, twin and earth cable isnt suitable to be externaly exposed
Depending on what activities you carry out on your workbench, you may wish to consider plastic conduit and metal clad sockets to protect the cables etc from impact damage etc
Your frendly electrician can discuss the part P options with you ;)
