I want to extend a ring circuit into a conservatory (Local BC say it is not notifiable).
As one of the cable runs crosses a doorway I was intending to use SWA for that run (not 50mm cover) and checking B&Q this morning the 1.5mm is rated at 28A (same as 1.5 t&E PVC which will be used on the other parts of the ring extension.
I was expecting to use 2.5mm SWA (same cross section as the 2.5 T&E)but looking at the rating am I OK with 1.5?
Circuit is protected by 32A MCB and 30ma/30MS RCD (Split load CU)
