Hello guys
Just checking to clarify some points.
I have a wall between a two rooms. That wall is hollow and without insulation. I checked.
I plan to extend a ground floor ring circuit by adding two double sockets on the ring and one spur at the end of those.
The total run in the cavity is no more than 10 feet. I figure it would be much neater to run the cable in the cavity, rather than use trunking on the wall.
I will appreciate all advice with many thanks.
Thank you.
Thank you.
