Apologies if this is listed already, looked fairly hard.
I have a conservatory (not yet plastered or floored) and am planning the electrics.
What is the recommended twin socket box depth for thermal block walls so as to sit flush? Also there is a perfect joint in ring main I can take either side of the door... How should I run this through the walls, 20mm conduit? How do I then run wiring to boxes, can I just cable to wall at what height or use a trunking?
All will be plastered and heated floor is being added.
