extension drainage
8 Sep 2005
worlds end
currently, the rainwater and gray water run to a combined pipe,some alterations are happening ,soil stack moved slightly and 4 drains added,but i was wondering will the rainwater off the 7-meter extension be allowed into the current set up or will it be a soakaway?
You need to ask the building control officer.
Generally rainwater should discharge into the ground within the curtilage, but Ive certainly had mixed drains allowed to stay as is -edpecially if the ground has low porosity.
