This may be a silly question, but am i able to wire an exterior light to an outside 13a socket with a light switch indoors. if so what flex and what sort of switch would i need
Seems an odd way of wiring a light. Can't you just have a plug in light with a PIR or just spur off your ring main somewhere or the light radial and use an FCU with a switch before it goes outside.
